Car Sounds Weird
Bokmal
Apr 3, 2009
Milwaukee, Wisconsin
Hey everyone, I have a 99 GSX eclipse. Recently at higher speeds like on the freeway (freeway speeds) I can hear a slight chirping that goes in and out where I can hear it then it goes away then it comes back again. Also, it doesn't seem like I have as much power with acceleration. It could be just be me, but what do you guys think this sound is?
Is it a chirping or a whistling? How much boost, what RPM? More info is needed but off the top off my head, just for an idea, I would say do a boost leak test. High pitched whistling or chirping from the engine bay is sometimes indicative of a vaccuum/ boost leak.
at high speeds it sounds like a chirping but when I give her gas in low gears it sounds like a whistling. i put her in neutral and coasted and gave it gas to listen to the engine and the engine sounds awesome and the engine vacuum gauge is steady at 20 lb.
I do have a 16G turbo and it is boosting at around 20 psi. However, I've also noticed the boost is not nearly as responsive because it takes longer for it to boost. Another thing is when I drive at higher speeds there is a big wobble. I just got home again and its 2:30 am so I haven't been able to take a good look at it, but tomorrow I will. Is the wobbling some sort of tubing that is dangling around?
All of this happened today by the way at the same timeish ;)
Ya the BOV was loose and the exhaust manifold gasket was tearing out after a bolt fell out. Thanks for your help
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
