Weird sounds after wheel change
Chrispittman
47
Jan 6, 2009
Arlington, Washington
All I did was go from 18" motegi wheels to OEM gsx wheels... now my breaks squeek, shit rattles, sounds like metal grinding together, sounds like gravel rolling around in my hatch. wtf..?
yeah they were on a 95 gs and worked fine. I did notice there's like a lip on my hub that collides with a lip on the wheel and so it doesn't seat all the way to the hub but that wouldn't cause all this crap would it..? and is a 95 gs and a 97 gs hub THAT different?
Did you use the correct lug nuts. I don't know what kind of lugs the motegis use but the stock wheels use a lug that has has a straight shaft instead of tapered like most lugs.
And yes if they are not sitting correctly against the hub that will cause some issues.
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
