Car shakes when braking
The1hiphop
Jan 11, 2005
Chicago, Illinois
When I hit about 45 MPH and I brake the car shakes realy bad . Someone told me that it is my roters please HELP
well whoever told you its your rotors is right. It shouldn't really matter what speed your at, your car will shake when you need to replace your rotors.
A brake job is easy, while your at it, buy a set of brake pads to go with your rotors. Total in parts will be about $150-190 (rough). Better than paying an arm and a leg to have a shop do it. Good luck. :thumb:
Thanks
Definitely sounds like you have some warped rotors. I would replace them rather than taking them to a machine shop and having them turned. I've found that it's pretty easy to warp rotors on our cars. Mitsu should have used bigger rotors. I should probably slow the **** down too.
Yeah, rotors dude. And you can get the parts for less then that, depends on how good of ones you want.
On the non turbo, I did front rotors and pads, and rear pads for about $80 total parts. I bought the cheapo stuff cause the car is a beater. They work really good too.
But if you like this car, and wanna keep it, you might wanna spend a little more on some brembo parts.
