NTRCOOL
- 0
- Apr 10, 2002
OVERHEATING? The issues and their solutions have remained the same- either you don't have enough cool air reaching the rad, there's a cooling system obstruction which is preventing coolant from circulating, or your head gasket has failed and is allowing coolant to be consumed or pushed away from the engine.
Discuss all possible overheating problems and solutions here.
OK,
I just left my house to go over to my GF's,and happen to look down and see my needle right before the red mark. This just happened out of nowhere. I stop the car as quickly as i can, and pour in some coolant(Coolant a little low). Still same thing. Welp im in the middle of the road, and HAD to get it home. Im only 5 min from my house. I decided to try and make it(I really had no other choice). Welp I drive no faster than 20mph, and the temp needle is BARELY into the red the whole way.And occasionaly to the left of it. Am I ok?? Do ya think any damage was done?? And im thinking either thermostat, or water pump. For each of those, whats a round about $$ figure to get replaced?? Any info you have would be GREATLY appreciated!
OK,
. Now I let it cool down put water in the radiator and it won't start. It look like I'm leaking from the waterpump? And I have a huge hole in the radiator. But when I try and crank it over it seems to turn over a bit slower than normal. Check the oil no water but smells like fuel. Can someone please tell me why it won't start?? Some of my buddys at my work think its the water pump but a few other say its the head gasket Thx guys!
, I added my 2 cents good luck. I'm just saying on every car I had to fix a headgasket on, Compression was so close, it wouldn't even be a clue to which cyl was getting leaked into.
