Car Overheated / Overheating / Overheats [MERGED]
NTRCOOL
Apr 10, 2002
OVERHEATING? The issues and their solutions have remained the same- either you don't have enough cool air reaching the rad, there's a cooling system obstruction which is preventing coolant from circulating, or your head gasket has failed and is allowing coolant to be consumed or pushed away from the engine.
Discuss all possible overheating problems and solutions here.
OK,
I just left my house to go over to my GF's,and happen to look down and see my needle right before the red mark. This just happened out of nowhere. I stop the car as quickly as i can, and pour in some coolant(Coolant a little low). Still same thing. Welp im in the middle of the road, and HAD to get it home. Im only 5 min from my house. I decided to try and make it(I really had no other choice). Welp I drive no faster than 20mph, and the temp needle is BARELY into the red the whole way.And occasionaly to the left of it. Am I ok?? Do ya think any damage was done?? And im thinking either thermostat, or water pump. For each of those, whats a round about $$ figure to get replaced?? Any info you have would be GREATLY appreciated!
Without the water pump working, you really only have the outside air and fan cooling your motor. That's why it will overheat at idle. Get that done ASAP! It might not hurt to get the timing belt done while they pull everything off for the pump.
Now regarding the rumbling noise thats coming. Could it be from the bottom end because thats what the mechanic is saying. He says it could be the waterpump and the pump is leaking for sure. Its rumbling almost a knocking noise coming from the intake manifold side. Is that waterpump fins, has anyone else had this experience?
You won't know until you actually replace the waterpump first. Use a process of elimination. The waterpump is a possibility, so replace it. If that doesn't eliminate the noise (or drop coolant temps), then move on to another section of the engine. To help pin point the sound, take a big funnel or the cardboard part of a paper towel role, and hear through it for where the sound could be coming from. Also check your radiator for small leaks and getting a lower degree thermostat could also help with your overheating problems at idle.
so i replaced my water pump and timing belt about 5 months ago. I added a 16g turbo with new manifold and exhaust, and the car would overheat at idle really bad. So i just replaced the radiator with a fluidyne and it still has the same problems. when i drive it starts to cool down better than before with the new radiator, but idle is whats killing me. could it be the thermostat of fan? would either of those make that big of a difference? i also installed all the heat shields.
Since thermostats are cheap, I would go ahead and replace it. Have you been monitoring your coolant levels? Take it for a drive, get it up to temp, then park it and leave it running. Pop the hood and wait for the fans to cycle. If they never turn on (probably should take less than five minutes) then they are your problem. But if the fans do turn on then they can be eliminated. Let us know.
If the thermostat is bad and is not opening there will be very little circulation of coolant which could make a big difference at idle, also the fans cool down the engine at idle alot too becasue there si no airflow without them.
are you burning or leaking coolant?
I woud check that and then the fan/thermostats. New thermostats are pretty chap.
Also, what kind of water pump did you use? I've seen cheap ones do some pretty weird things in the past.
well i got an oem replacement pump, and did the head gasket also. im going to try the thermostat and check the fans. i may turn the on at all times with the dsm link. ill let you guys know. Thanks for the advice.
Alright I I have just dropped in my built motor, everything runs fine. EXCEPT every 2 miles EXACTLY (kind of odd) the temps will start to go up and it starts to overheat.
The water pump is new, I have a new MLS Head Gasket , I'm replacing the radiator as we speak but it looks to be good and worked on the car before the swap, i replaced the thermostat, replaced the radiator cap, burped the system added 2 slim fans, did a block test, head has been milled, block decked. I am stumped.
any ideas?
I have the SSAC 2g FMIC, with 1 slimline fan. Once I get the radiator I'll be adding a second one(fan). I'm just hoping this isn't because of the head gasket not sealing correctly, that would really suck pulling everything apart again.
check for coolant leaks, just the other day i was driving and i started smoking white out of my engine bay, looked down and my temp was almost at high. i pulled over and had no coolant in my radiator hose. just randomly started leaking. make sure you have coolant though, and are not leaking in some hose in the very back of your engine bay like mine did.
Funny thing is too, theres no smoke at all and no smell of coolant at all. I will check the heater hoses, haven't thought of that, but I'm not losing coolant other then when I get hot and what comes out of the overflow tank
What is the correct way the fans should be spinning? should it be pushing air through the radiator and out towards the bumper or pulling the air back towards the engine bay?
Replaced the radiator (stock one wasn't that bad) and wired in the a/c fan. Everything looks alright for the moment. I'll keep you posted.
if it heats up again check the heater core. It's probably your FMIC blocking airflow. I'm having this issue this summer also. If you have room setup two puller fans(like you did) or if you have to ty setting them up in front of rad as pushers.
