car misfiring bad
Infiltrate2000
172
Dec 27, 2003
QUEENS, New York
car misfire badly after 3k rpm, car basically stop dead in it track until u let go of the gas and then gas it again or shift to another gear. I changed the spark plugs and wires two days ago, but it did not help.
So car is running either rich or lean, because it make a popping noise very often when i shift.
I know of the following problems already, bov does not recirculates, its an apexi, has no recirculation kit. Exhuast have a leak on downpipe or next to it. But i don't think this can make the car misfire so bad, let me know what you guys think.
Probably not by itself but add boost leaks to that and you got problems. I suggest performing a leak test and replace the BOV with something that can be recirculated, that or upgrade to a blow through setup.
