car keeps shutting off need fcd help
dsmking101
224
May 13, 2009
????, Utah
i had this problem ever since i finished my turbo install the car will turn on good and idle for about 45 secounds or so then stutter and die then i will have to wait a couple minutes then crank it and itll turn back on with no problem and do the same thing afther a few secounds.......when i drive it drives perfect on the road but if i come to a stop itll stutter then die and wont turn back on intill a minute or 2 passes......i havent installed my fcd could this be why? heres a pic maybe you guys can give me a lil addvice on how to installl or help me to figgure this problem out :confused:
i connected it to the maf and used a mullti metter and turned the lil screw on the side to tune its volts to 4.6 or 4.5 but the mullti metter is not reading anything no pressure ...it could be installed wrong please help thanks
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
