Car idling high..rpms take long time to fall
a_scobel
5,403
24
Jun 6, 2003
Alexandria, Virginia
When I first start my car up, it'll idle somewhere between 1000 and 1500. The BISS screw is backed out about 1½ turns. I ohmed out the TPS and the ISC, they're both fine. Did a boost leak test...didn't hear anything. When I'm coming to a stop sign & push the clutch in, the rpms will go up to about 2k. When I shift, also, the rpms take longer to fall than usual. They'll stay at the rpm that I shifted at for about 2 seconds, then slowly (not TOO slow, though) start to fall back down. I WD40'd the sh*t out of the throttle cable, too.
Thanks in advance!
monroeh said:
Have you done any upgrades lately?
I cut the BOV dump tube & cleaned out the intercooler with gasoline (I let it dry out for about 2 days before putting it back in), cleaned the throttle body following instructions from VFAQ (Except I used brake cleaner instead of carb cleaner, let dry for a couple days also), and changed the intake manifold gasket. (I did a boost leak test, and there's none).
2gGSX said:
Keep playing with the BISS would be my advice
Turned the BISS all the way in, all the way out...did nothing but make it idle higher. So I turned it all the way in, then backed it out about 1½ turns.
