2G car hiccups after BOV
DSMTyson
1,225
10
Nov 9, 2010
Lake Charles, Louisiana
When i get in the boost and then let off the gas, thus making the BOV go off, my car hiccups, the rpms drop then go back to where they were, and my afr's go way rich then clear up when the rpms go back to normal. It happens at any boost level, it could be 2 or it could be 22, either way it still does it..
Anyone experience a problem like this before?
it is recirculated
What kind of BOV is it? Do a BLT? adjust your BOV softer, see what happens.
Nice DSM BTW
Its a Greddy Type s(junk, i know.).
I've done a BLT, i have a leak at the compressor housing where the o-ring for the cover is. I think its dried out and cracking, i just ordered a new one from machv.com. But could that really be causing this?
I have done the single spring mod for my bov(where you take the softer spring out and leave the other in). And adjusted it to be softer, and it helped a little, not a lot).
And thank you very much, the pictures don't do her justice, she looks much better in person.
so is it safe to say that my boost leak is causing this? or do you guys think it could be something else.
A boost leak could definitely cause it.
Do a BLT, fix the leaks, and see if the issue goes away.
Yea, it "hiccups" because the BOV spring is more than likely too compressed (therefore exerting too much pressure on the piston), and not letting out enough air, resulting in compressor surge.
