vintagemuscle
- 329
- 11
- Jul 19, 2005
north olmsted,
Ohio
I was driving to the track yesterday and got caught in a huge thunderstorm. i went through many deep puddles and got most of the engine bay wet. today when i drove the car everything seemed fine until i went wot and then immediately the car will sputter and not boost past about 8psi. at part throttle the car runs excellent and will boost fine. i got it to about 12psi at part throttle without sputtering but as soon as i go wot the car falls on its face. i went home and pulled the air filter and tried it again with the same results. i figured the air filter was still wet causing the problem but it wasn't. i probably ingested some water but could it have made it all the way through the intercooler to ruin my gm maf which is right at the throttle body elbow? would a bad maf cause these symptoms. also, now my logger doesn't work. when i turn it on is says it has no connection with the car. this is leading me to believe the problem is electrical. it's too late to mess with it now but tommorrow i will get to the bottom of it, hopefully. any suggetions?
