Car Finally Died
2002SL1
89
Apr 21, 2005
Colorado Spring, Colorado
After 2 Years of abuse for a 50Trim running at 35psi on a stock block with 200,000 miles on it my car finally couldnt take any more.
Oh well more to the point. I'm getting the Motor, Transmission & Head Rebuild Slapping on a new exhaust manifold & turbo Charger.
Eagle Rods
Wiseco Pistons
Crower 288 Cams
Crower Valve Springs
Jacks Transmissons Premium Rebuild
PTT Twin Disc Clutch
Full Race Manifold
T3/T67 H.O. Turbo
Let me know if there is anything that you think I should change on there. The car Runs on E85 and is only Driven about 2-7 times a month, Mainly to the Drag Strip. I'm trying to get about 600hp out of the car without Nitrous.
yo whats the compress supposed to be at...... and how would i check my wastegate?
let me know about the headgasket to!!!
thanks tone:thumb::thumb:
srry yo i hit next tread and throw in my own tread... my bad man sweet tsi man..
i plan to rebuild my 4g63t due to turbo problems..
tone
BS is already out of the car.
I knew I should of Taken Pictures.
Car is already in the shop and being rebuilt, makes things alot eaiser when you have a lift work with. Looks like all it was was just a crushed ring, really easy to fix but im doing the whole thing from top to bottom. (Head only has about 600 miles on it).
Its amazing what you can do to a car when you are running E85 Through it.
My goal this year is a low 11 on street tires (No Slicks or Radials), I really dont think it is going to happen but hey im going to try. I did hit a 12.5 last year on a burnt out stock clutch and my old setup (I think our strip is 4800 feet ASL). I do still have to drive my car to the track which is about 55 miles away so it does have to be somewhat "Streetable". My biggest worry about all of this is ending up with a trailer queen when im done.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
