cant hit boost ### help
96gst_10psi
Jun 25, 2009
stoughton, Wisconsin
ok so i have a 96 gst with 16g turbo front mount and welbro 255 pump it ran perfect when i got it and now as soon as it goes over 5 pounts of boost it just has no power it wont go over 4000 rpms if pedal is to the floor i had a couple boost leaks i fixed i have new plugs wires cam sensor crank sensor and just did timing ### help out of ideas
it just stops accelerating and tonight i put a new timing belt on and did timing and it drove fine still had the same problem but then i let it sit and started it and now it runs like crap and keeps dieing but i also found a pin size hole in tubing could that make it not run good under boost
Have you thought about getting a tuning device such as an afc ? It sounds to me like you are running rich and flooding your injectors. you need to tune your car at least for your 255 to work properly with your stock fuel injectors/fpr.
