HELP Cant find boost leak *Video*
le0net
57
Mar 31, 2006
Stockholm, Europe
Hi!
Found some threads covering this, but didnt get an answer, hoping i could get some more ideas here.
Have new injectors, new seals, made a IC tester and connected it before the GM MAF, see picture. When i pressurize up to 4 bar i just hear a hissing from the "backside" of the intake, but cant find a leak, you can hear that in the video.
Sprayed on soap water and found a leak at the AFR, the threads were leaking so i put some thread tape on, now thats ok, checked all houses, sprayed soap water everywhere but can find the leak.
All tips would be appreciated...
Small Video
Big Video
Didnt help, still leaking from the first PSI.
So the intake itself is ok, i made a compression test to check that the valves are ok, got 1=170psi, 2=165psi, 3=175psi, 4=175psi so they feel ok.
Finally ordered a new OEM manifold gasket,
need to wait a week for it from jnz, thats my last hope, didnt find any here in Sweden.
UPDATE....
So the intake gasket didnt help so i took everything apart, and found the problem.
It was the EGR block plate i made, i did it the wrong way so it leaked from the intake side to the exhaust side. Made a new block plate and put everything back, at the same time i found the wastgate wasnt sealing properly when closed so i fixed that too.
Now im driving around with the car and have more power/responce than before, increasing boost little by little and doing some tuning.
L
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
