cant get balace shaft bearing out.
1sick91tsi
149
Feb 13, 2004
pipersville, Pennsylvania
ok well heres the problem, trying to put my balance shaft eliminator kit in and i just cant seem to get them pesky bearings out. tried using a flat head tapped all around it slowly and nothing is happening. if i cant these out what should i do, can i just jb weld over the holes or what? thanks got the help guys.
Go out to Autozone, etc. and rent a bearing driver. Its a long rod w/ different size heads you put on to correctly drive out or put in bearings.
Heres a pic of the driver kit.
And you can use revese the balance shaft to pop out the inner bearing.
How much does one of those kits run?
Mike
