can someone explain this horn me
Talon00b
138
Jul 30, 2005
London,
Ok as many of you know Im ready to take the talon to saftey except for the horn... its not the horns it self because i tryed them with power to each and they worked...so I took the horn button on the stering wheel apart and i see a red wire connected... now is this red wire sapos to have constant power wire? or is this a ground? Im just thinking if i can find another power source to make the horn work that would make my life easyer
any help would be great
The horn is not +/- power concious. My horn wasn't working. I I try the horn on aonther car and it didn't work. I got a new one for like $13 from an autostore. It still didn't work, so I checked all the cables, it turned out to be a blown fuse. Man would I have saved some time if I checked the fuse bax first. Let me know if it helped any.
is there another fuse other then the fuse in the driver side fuse box? maybe im missing something here... I tryed the horns and they all work
so whats that red wire then if its not positive or negitive?
The horn buttons complete the curcuit to ground when activated. There is a relay between the buttons and the horns, though I don't know where it is.
