1g CAS.. Can someone explain this...
mko
43
Nov 26, 2009
Woodbine, New Jersey
..I dont get it somehow. Its from Magnus M. manual for 1g CAS in 95 2g DSM.
Pin 1 is now pin 14
Pin 2 is now pin 1
Pin 15 is now pin 2
Pin 14 is now pin 15
I dont get it. Can someone put it like injector 1 for injector 3....this kind of language.
^I think thats only for 97-99. 95-96 uses a CAS that is mounted at the intake cam gear and it provides 180 deg flipped cam signal. The injector wires and the spark plug wires need to be switched around
It says for 95-96 2g's. It shows flipping pins for cas inversion.
Sent from my Droid
Ive done this before. The pin thing is to get the car running right. The starting firing order is 4 1 2 3 ( thats the way it is with any 4 cyl car )
basically you have to change that order when you wire up the 1g CAS
its either 3 2 1 4
or something close to that, look it up but youll know when you get it. The car will fire right up
The pin thing is to make sure you dont get the CEL to pop up. It will run fine without you messing with the pins so:
Wire up the 1g CAS like it states
get it to run without messing with the pins
then when shes running, go after the pins on the ecu
this is how i got a 95 2g to work
good luck
I was kind of tired last night. I woke up today and I knew what do to. Took me a min.
Thanks for the replies guys!
She's running again
