4G63GS
- 0
- Mar 23, 2005
suffolk,
Virginia
just got done building my 4g63. All new stuff including overbored cylinders and stuff like that. I get the timing set and start it up. I do the process for setting ignition timing to +5. I have the cam angle sensor all the way to the right ( looking at the motor from the drivers side) and look at the mark on the crank. It is an inch away from btdc and nowhere near the marks. When I adjust the cam angle sensor it just goes farther away from the marks. Could it be possible that timing is off by one tooth? I tried to 180 out the cam angle sensor with no luck. It still is way off. help someone
