Can i re-use this?
'97boostinGST
1,102
Mar 1, 2010
Oxnard, California
So after two years of waiting im finally going to start my build, about 2 months ago i had a clutch job done with all the works new OEM everything with Redline fluids. Can i re-use the fluid? It has maybe about 2k miles or should i go ahead and buy new fluids? And are the tob,tob clip, ball and fork re-usable after 2k miles?
Also, how do i go about cleaning the oil pan and pick up tube? I'm sure that after 150k miles, it isnt going to look clean at all.
Thanks.
Don't question that. Unfortunately no one is going to suggest reusing fluid, ever. Sure there are methods to do it, but why? Go get new fluid and be done with it. It's the smartest/safest thing to do. Suggesting otherwise is just negligence/cutting corners.
The clutch and flywheel and throwout bearing/fork&ball you can re-use it since u just changed it. You gotta get new fluids, and as far as the oil pan goes, and pick up tube, you can use some degreaser and scrub them clean or take it to a shop to get them cleaned with their Parts Cleaner.
Cool, thanks Alex.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
