Can anyone tell me what valve springs these are??
2GFWDbeast
1,094
15
Jan 17, 2010
kenosha, Wisconsin
They were already in the car when i bought it have no idea if there stock or what. Anyone have a good guess, there in my 1990 gsx.
i have the valve cover off my car went outside to check and both of ours look identical so i would def say stock also i run 272 on stock valve train its a common thing to do when u dont want to spend the extra money
I am almost 99% sure that they are stock or at best Evo springs and retainers which is a good upgrade. However, stock can and has handled HKS 272s, so for your own safety, consider them stock even if they aren't and plan to upgrade one day.
They look like the stockers that I have here with me at work. A 3 angle vavle job is the standard nothing special there. Deff not evos as they would be behive and the retainer would be aluminum which that one looks to be steel.
ok what is the advantage to having after market springs
several..... stronger, better, help keep from floating a valve, handle up better to the stress of a bigger cam. take your pick. pretty much everything can be upgraded, it just depends on how much you want to spend.
