1G Can anyone Identify these Valve Springs?
KeithAZ
90
4
May 20, 2015
Gilbert, Arizona
Can anyone identify these Dual Valve Springs? I am trying to contact the manufacturer due to an issue of the valve spring seat being in the way of putting on the ARP Nut.
Thank you, I have read it already. My problem isn't with the washer. All the washers fit fine. The nut is what is hitting the valve spring seat.
It makes sense to a point. I think my last resort is taking it back to the machine shop. As it looks to me. When I tighten the nut down (if it's even possible to get it on) it will be at the same spot as where the valve spring seat is causing Interface.
Have you tried putting the washers and nuts in the head before sliding it over the studs and slowly lower it down slowly while tightening all the nuts a little at a time? Probably a 2 person job.
