Can anyone intertify 6-bolt or 7-bolt?
kind of hard to say from just looking from the top part. look at that link ^
well by the pick is kinda hard, considering its a 93, probley the early 7bolts.
looks like a 6 tah me, from the intake manifold to the thermostat neck, i maybe wrng
Uh......no. Just because it has a 1g manifold and thermostat neck doesn't mean it's a 6 bolt. BTW, his car is a 1g.
Is their any other really tell tale signs?
Just go feel the oil pan like described in the link I gave you. You should be able to figure it out in a few seconds. Or you can drop the trans and take a look.
Well, if it has the original 93 engine, it will be a 1g 7 bolt, which are much different than the 95+ 7 bolt engines. So for sure, it doesn't have a 95+ 7 bolt engine.
But seriously, go slide your hand and feel the timing belt side of the oil pan, it takes about 5 seconds to figure it out.
