Came across HKS 264/272 cams couple questions
SpoolN
386
Jan 20, 2003
Coventry, Rhode Island
Just came across a set of HKS 264/272 cams just wondering if these can be run on a stock head, or will I need to upgrade springs, any head componets, cam gears. Or will my stock head be okay. Thanks
They are fine to run on the stock valvetrain. If you go more aggressive than that 272's then you will have to upgrade but you will be fine with what you have.
I run FP2's front and back on the stock valvetrain with no problems so far.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
