hks 272 cams
Honda hunter 1
83
Nov 4, 2009
magog, Vermont
I,m thinking of buying a set of hks 272 cams ,my set up is stock 6bolts motor,holset hx35 7blade ,pte 780cc,big fmic ecm link v2.5,mas 2g,intake 4inch fp,bov 1g,walbro 255,3inch exhaust,external wg, pump gas 94oct.The most air flow that I got out of my holset is 46 pound per minute ,if i install some hks 272 cames will I get more air flow out of my turbo, I only use my car for racing at the track 1\8mille my best time is 7.72.
whats your current set up when it comes to cams? if youre going from stock to 272's there should be some more midrange power ie around 2k. Seeing as the key to power is more airflow Im pretty sure it will increase air flow to youre turbo
