cam sensor
16vdohcturboawd
447
Apr 15, 2003
the moon, Maine
can you use a 94 CAS off a 7 bolt motor on a 90 6 bolt engine is there any specific way it needs to be installed?
dave99gst said:
what year car is it going in ?
if its a 90 - then ya gota wire it in.
Yes dave the motor i am using is a 90, now should i use the 90 crank sensor that came on it or the one of the 94 motor? the one off the 94 will connect up, but the car wont start unless i spray gas in the intake. the 90 CAS connector wont fit? if i have to use that one how do i rewire it, there are four wires on each but the colors are different, i have found many diagrams for 2gs just none for 1gs, i know this can be done i am just stumped as to how. my other question is, is there a special way to install these like moving the number 1 cylinder to tdc or do you just bolt it on? thank you for any help on this i really need it :)
