Buzzing noise
Kastigir
245
Sep 22, 2008
Cincinnati, Ohio
What, in the passenger floorboard area, would cause a buzzing noise when attempting to start a 96 TSi? The car does not turn over, and the last time it was started was a push-start.
It may be a long shot but if you don't have your fuel pump re-wired then it could be that. Our fuel pumps don't kick on without us engaging the starter
Infinity system long since removed, and it has started by a push start. It wouldn't start that way the other day, but it has been sitting for a while now.
I feel like a moron, but not totally because I don't really have the facilities to work on a car very much. It was apparently a loose connection at the starter. We did get it started by a push start, and over to a friends house where he took a look at it today and figured it out.
Also, had an overheating problem that I was sure was another failed thermostat, so we removed it and the overheating problem is gone, and surprisingly I still have heat.
I will however keep in mind those 2 relays for the future. I was suspecting relays beforehand, but were unsure if any were in that area.
Thanks for the help.
