Weird Buzzing Noise
Karma
142
Mar 12, 2006
Sherwood Park,
So today I just finished putting the car back together. I put the key in to the "on" position to make sure everything electricial worked. However when I turned the key "off" there was a buzzing that last for about 5 seconds coming from under the dash, near the fuse box. It only lasts for 5 seconds but it happens everytime I take the key out. What the hell is this!? (I was working under the dash this winter taking out the pedal assembly, so I may have un hooked something. Also it didnt make this before I parked it for the winter)
The buzzing is probably a relay. There are a few above the inside fuse box. There like black cube about 1inx1inx1in. Take one out, turn the key, see if theres no buzzing. Find the one thats buzzing and we can see what to do from there.
You were right! I had 2 relays wired in for my alarm's power door locks. The wires were not attached properly, so I used female spade connectors. That fixed the problem.
Thanks!
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
