heinzanova
- 0
- Jul 3, 2004
Stroudsburg,
Pennsylvania
I Just put a down payment on a 1992 Eagle Talon TSi FWD
It has a 6bolt that was just rebuilt 1000 miles ago buy a local mechanic that has worked on many DSMs and Mitsu Staliens/Conquests. So i know the rebuild is very trustable.
It has a Big 16G with no play at all, boosts very healthy.
Manual boost controller
Cut Air Box (Still has honey combs so mas can read properly)
K&N
When he rebuild the Motor he did the Balance Elemination Kit
Under Drive Pulley
3Inch Cat Back APEXi (GT series)
No Upgraded DownPipe or Test Pipe (factory DP and cat)
Auto Meter Boost Gauge
Auto Meter Colbalt Series A/F Gauge
Reinforced with Eutothain (spelling?) bushings
ACT Street Application Racing Clutch
Stainless Steel Braded Clutch Line
All Fuilds, Belts and such are brand new.
My question is, where do I go from here? I have a limited budget for more parts this summer, but it is obvious, when the car is at 15PSI on the stock fuel system that there is hesistation in the car, could it be the computer is backing off the timing because of lack of fuel? It hits the 15PSI like nothing, and you can hear the turbo just wanna run like a monster. The A/F gauge reads lean while in idle, but soon as I get on it a little it moves up to the center, on a scale of 1-10 (1 lean 3-8 Stochi and 10 rich) it idles at 1, and runs at like 4/5ish.
(please dont bash me for this horrible rendition of the gauge performance)
I was thinking of larger injectors, AFC, and I was told I must replace the fuel pump if I am going todo larget injectors?
Would this be the wisest upgrade at the current time?
K&N
Under Drive Pulley
