Busted rubber on fuel feed line
oplix
217
Mar 9, 2008
Zion, Illinois
the rubber on the banjo line from sending unit to hardline broke and started leaking really bad. I didn't damage the flare fitting or anything but I need to know a cheap way to fix it. Any suggestions? (I am not replacing the whole fuel feed line to a SS one right now).
I just need that one portion of the line fixed.
heres pics.
The piece in the first pic see if that threads onto the thread on the fuel pump, if so a short 6an with 2 fittings would be as easy fix.
yes it threads on..i just took it off. where can i get a fitting like the one you mentioned?
