buschur shortblocks
mattspyder
1,046
Nov 2, 2004
del taco, Wisconsin
I'm looking at getting one of buschur racings shortblocks, either the stage I or II ( havent decided yet) I'm looking for some feedback on customers that have purchased from them. I'm alittle scared about purchasing a Engine block over the internet. I know they have the fastest dsm in the world that did 6-7 seconds numberous times. I want to do a 6 bolt swap on my spyder and put a evo 3 16g turbo on. Another question. I have a 2g Head that i would like to keep, Can I port it to match the 6 bolt block? or should I just get a 1g head and put that on? Can I get some of your thoughts? thank you
Shep ran all last year on the same block, Buschur does great work. I have their stage 3 head and am happy with it.
with the flow differnce in the 1g head I would save time and just pick one up it will work better for you in the long run. I live very close to Daves shop he is a good guy and wont rip you off, he has been in this business a long time. Shoot him an email and he will give you all the info you need on his products.
You don't have to port match the 2g head to a 6 bolt block. Also you will not see much if any differences from a 2g head to a 1g head till like 600hp. The reason 2g heads suck from the factory is because of crappy cams and crappy intake manifold design. You will even make more tq with a 2g head.
Also why would you be scared of buying a block from them over the internet? They are a well known shop with a solid reputation. I don't think you have anything to worry about.
Do you have a background in modeling fluid flow? CFD perhaps?
I do...Hes wrong.
The 2g head flows better till you get into airflows in the V trim 57 turbo range. Intake port velocity is more important at lower volume flow rates then intake port volume. Unless you plan on putting a big honking turbo on a car then stick to a 2g head thats mildly ported for clean up and a good set of cams like the FP1 or 2.
Nanan said:
I do...Hes wrong.
For what its worth people are pushing those head farther than that pretty easy. Blueballz on here made just over 600awhp on a stock 2g head. I am curious what a good port job on a 2g head would do. And I mean going up on the runners and not touching the floor at all.
Nanan said:
I do...Hes wrong.
As do I but I was hoping he would "prove" his comments. Thanks for chiming in with solid information.
