Bullseye turbos?
paintball4fun21
168
Jun 13, 2006
onalaska, Wisconsin
im looking for a 400hp goal.......are bullseye turbos descent? and if so what one would be the best(have most supporting mods and im ordering injectors and dsm link) ....im looking in the 700$ range
thanks!
also these turbos bolt onto the stock manifold but are externally gated........where can i get a new manifold that it will fit and also i want to vent it to the atmosphere.....will i just have to custom weld a dump tube?
bullseye offers the bolt on mitsu housing for almost all of their turbos. I recently for an S256 and my goals are about 450whp on pump which i can see as being very realistic with this turbo. Aside from that they usually have plenty of other options like the 50, 57, 60 and 60-1. Any of these can achieve you goals it all just depends where you want your power to shine the most.
I don't get your question in regards to the wastegate? You can get any of their turbos in an internal gate and i have used several with tremendous success. If you really want to go External you can pick up an SBR manifold for a 38mm gate or pick up one of the SS o2 housing like the ones that we use with 38mm gate flanges off of the O2.
ok cool.............as for power i just want a bit of a wider range...not just spooling super fast or super slow.......ummm im still not really sure what to get....i really wanna see what others have had success with and maybe go from there
thanks!
at the moment, im set on a pte 5031e. extremepsi has that turbo w/ the install kit for around $900. the turbo bolts to the stock manifold...im just gonna port my stocker. this turbo they say is good for up to 450hp...im looking to shoot for mid-high 300s.
ive heard of bullseye, but i dont know of anyone using their products.
