bullseye to4b v-trim turbo review: (times/whp)
Here's a quote
You'll notice in the video and by the Dyno chart that the wastegate was opening at around 12 psi making it slow to spool. Rocky doesn't use a boost controller and the adjustable actuator was set a little too loose. Everyone is very confident that this set up will break the 400 whp mark in the coming months
my_gst95 said:
Only some sort of logger will truly tell you this. If you don't go around punching the car for the few days your on stock injectors, I'd say you'd be "OK".
my_gst95
You can, I've been doing it for the past couple months. Just don't get too anxious and get WOT hungry. :thumb:
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
