building my engine with 2.4l stroker
thesmartestyet
74
Aug 11, 2007
coghlan, New York
im geting ready to buy a 2.4l stroker kit but i havnt decided what turbo set up im going to use i was thinking GT35R82R but im not sure i would like to make 600AWHP im looking for everyones input tell me what you think of the set up
Are you looking for 600 whp on pump gas or racing gas? The GT35 is capable of 600 whp but it will take a fine tuned setup to do so. I looked at your mod like. You have a few things you are going to need to upgrade first: fuel pump, injectors, tuning device, etc; before you are ready for this turbo and those power levels.
i plan on running pump gas i plan on upgrading just about everything on my engine and then having the car dyno tuned once all done
I'm building a 2.4L stroker. I'm not going for 600 WHP, but my internals are pretty stout. If you want to know what's in it, look in my blog.
Why does everyone keep calling it a 2.4l stroker? There's no such thing! It's either a 2.4l, stroker (2.3l), or destroked (2.1l).
Technically... If you take a 2.0L Block and bore it .040 over that adds 1mm to the bore. You now take from 85mm to 86mm. Then you take a 102mm (stroker) crank and put it in the engine. Now you move up to just at 2.37 liters. Of course in the magical world of engine building you always round, so that brings you to 2.4L Stroker Engine!
