Build Questions. Help please.
conor14
45
Mar 24, 2011
st. albert, AB, Canada
tried looking this stuff up but cant find it ( sorry if its right infront of me and i didnt see it im tired as shit )
Ok so i got a Big 16g and a RRE 2.5inch to 3inch dp.
will the downpipe bolt right on to the 16g? or do i need some sort of adapter?
what size o2 housing do i need? if my downpipe is 2.5 do i get a 2.5 inch o2 housing? sorry this is my first build no idea where it actually goes. haha
will the oil and coolant lines from my 1g automatics 13g fit the new 16g?
if i send my ECU into ECMlink and get the non eprom upgrade can i tune off that? or still need to get a dsmlink?
Thanks again in advance. ive been trying to find answers and i keep getting different ones
If you have 1g o2 and exhaust manifold I would upgrade to the 2g o2 housing and 2g manifold they are better then the 1g ones.But that dp should bolt up to both of them.Don't hesitate to get ecmlink they got non eprom coversions they can do.I am not sure if the oil and coolant lines from your 1g automatic 13g will fit the new 16g.
i bought an aftermarket Exhaust manifold, the only part i need is the o2 housing now,
so does the size of my dp matter? if its 2.5inch? do i get a 2.5inch o2 housing?
Not really I am running stock 2g o2 housing on a 2.5 inch to 3 inch downpipe.I would just get stock 2g o2 housing and you should be good.:thumb:
