1G Budget dual piston brake upgrade for 1Ga
leakyfaucet
818
May 29, 2004
cincinnati, Vermont
Hi, I'm looking to upgrade the front brakes on a 91 AWD to the 93+ AWD brakes. What is the least expensive approach to doing this without buying used brake parts? While I was at it, I figured I'd shell out a little more and get some better rotors. I was thinking of buying stock 93+ sized drilled brembo rotors from ebay, and buying pads and remanufactured calipers from a local autozone type store. Does that sound good? Where would be a good place to get quality SS brake lines?
Also, is it possible to throw the stock front rotors and calipers on the rear? They're still good, so I don't want to just get rid of them. Obviously you would have to make brackets for the calipers, but is this possible? Would this totally screw up the braking balance?
Thanks!
The fronts won't fit in the back, different style hubs, brackets like you said, parking brake. Wouldn't be worth it. As far as the parts for the upgraded front brakes, that is how I would do it. If you do need brackets for the different calipers, I would just get them from a junkyard.
