2G Broken window guide roller help
TypeONegative
5+ Year Contributor
130
15
Oct 15, 2017
Utica, New York
Where do I find one? Just got my gst and this is what I found to be the reason my window wasn't lined up, can' find them listed anywhere, if I go to the junkyard can I remove one? Or will it just break?
Check your local auto store for the roller pack by Dorman #74430. You may be able to adapt one of the three different style rollers in the package, to work for your application.
Do they snap on to the metal part on my glass? I will try to order that part number thanks a million
Which car and which window. I just had this happen to my spyder passenger rear glass. I was going to fabricate the pieces myself but I gave up and went to Miller imports for a used piece. He suggested the whole rear quarter and track with the rollers. Glad I did it that way.
^OPs GST is hardtop. But def hit up steve Miller for one unless you want to roam the junkyard
Will the stud the wheel mounts on turn off? There's a notch on each side like it might be removable, my local junkyard has a early 2000s eclipse gt and I looked up side glass for it on ebay of the 2000 style, it looks the same do you think I can remove one and fit it on my car? Thanks
i may still have a few. i see if i can find them.
-------nope. i found one and its broken. sorry
Thanks so much! I love this forum! I found a window with all the rollers for 32 dollars with 20 dollars shipping, the seller agreed to remove the wheels/rollers and let me have them for 32 dollars plus 3 dollar shipping, thanks anyways very nice of you! If anyone here needs one just pm me I won't charge anything. I have almost everything I ordered just waiting for some clips that hold the carpet cover thing on the hatch and a seat belt top cover for the back seat almost there then I'll sand and paint the car
Fixing a rear window now. How did you replace the roller? The double roller one has a screw (may have been replaced in the past). The one broken now is the one farthest from the double which a post with no way to remove the post. The roller part broker in half and came off. Is there something that I can just push a roller over the post? Maybe take a dorman one, heat the post to remove the plastic part and while melty, push it on the pin? One of the Dorman parts has a bolt - I may be able to grind off the post and stick this one in there. I think others have done this.
