broken thrust bearing
They're not broken, you have a 3-peice thrust bearing (which didn't come in 95-96 blocks). Make sure the block is machined for a split thrust bearing, if not then you have the wrong bearings.
How do I check to see if it's machined for a split bearing or not? Do I need to take it to a shop?
Here's what the block looks like.
[/URL][/IMG]
[/URL][/IMG]
