Brights aren't bright????
SBstar
3,038
125
Jan 1, 2004
Jackson, Michigan
So guys just wondering if any of you actually have this problem too. When i turn my brights on the light doesn't shine any farther forward just farther to the sides and seems brighter. Its kinda weird and it happened when i had the regular bulbs and now the blue xenon bulbs as well. Perhaps i'm just crazy LOL
try goign with a name brand buld like the sylvania. I found if you fit the low beams with the high beam bulb by taking a dremel tool and cutting off the notches that get in the way you should be fine on both accounts then just put more high beams in the actual high beam slot. Worked for me
yeah i had the same problem..then i did that and i never needed my brights heh...and its somewhat legal
Yeah i was kinda wondering if perhaps they're pointed to far down or something. I was in a hurry installing them and they seemed ok. Cause thats how they always worked. But yeah definately should check them out again.
yeah pull it out on the road and check the level on the headlights and make sure its level i had that problem too when i got the car...the last guy had one right and the other way off
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
