Dash Lights Aren't On
Kinsey21300
Jan 13, 2005
Pittsburgh, Pennsylvania
Ok here's the deal, my dash lights don't come on. I'm pretty sure its the relay on my dimmer switch but i'm not sure so if anybody definetly knows, lemme know. Oh yeah and if anybody got a dimmer switch they wanna get rid of just tell me. :talon:
There's a fuse under the hood for the dash lights. Check there first.
Your dash lights may not be working to warn you that there is another problem, check all your fuses, make sure all of your lights and things are working, whatever you do, don't replace a fuse with a larger amp fuse than what belongs in that spot. I had two wires ground each other out behind my radio a few months after i bought the car, a lot of stuff stopped working, including my dash lights.
I checked all my fuses and they're fine, I also made sure the right amp fuse was in each spot. I'll check behind my cd player to see if sumthing wrong back there just incase. 1 other person told me it might be my dimmer switch. Any idea on how to see if thats wats up? :talon:
Check your tail lights, dash lights go out when your tail lights do to warn you.
