BOV on a automatic?
Stoofed
Sep 16, 2013
Layton, Utah
I have a automatic eclipse and was wondering if it would be worth it to install a bov in it? Can I get your opinions?
im going to assume you mean an aftermarket BOV because they have one from the factory. if so is your auto a 1g or a 2g. if 1g the factory will be just fine. if a 2g yes its worth it the factory ones are plastic and are garbage.
From your profile I'm assuming your 100% stock , so you have the factory plastic 2g bov - auto or not.
A reliable , cheap replacement is a 1g bov from the 90-94 cars , not plastic and can hold pressure much better than the factory 2g.
If you choose an aftermarket replacement make sure you recirculate it back to intake , if not between shifts you will lose air pressure that has already been measured by the MAF , and could result in some undesirable conditions.
Sorry I don't know much. What do you mean by recirculate?
Please post a picture of your engine bay for your own sake. And save any further confusion. Hey and welcome. I went to job corps in clearfield, was in Layton a lot, nice place.
  • Wanted 6 bolt NT water pipe
    • chrisman287
