bouncing speedo needle
white92tsi
48
Mar 15, 2014
De Soto, Kansas
The speedometer needle on my car bounces up and down. Sometimes a lot, sometimes none at all. When it bounces, I hear a shh shh shh sound, and when it isn't bouncing, I can still hear a chirp or a squeel coming from the dash.
Do these cars have cable driven speedometers or electric? Also, is this a common issue?
Thanks
Electronic, There is a plug for the speed on the trans. I would check that out. Those are kind of weird noises for a dash to make, are you sure its your cluster making those sounds?
Absolutely sure. The sound matches the bounce. I'm assuming it's the gauge itself. There's no pattern (speed, load, etc) that it does it by. It appears to be completely random.
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
