both windows dont roll down
Also in your manual it doesnt show a power windows fuse so i filled every fuse with a 10amp fuse and then my windows worked :D. Well at least on my 1g.
I took of the door panels off and the connections are good. I dont have a light thing to test for power. I checked all the fuses and the are good. I found a ground wire that came disconnected under the dash and spliced it back together. Its really my friends car. Can the windows open with the motor off and the ignition on.
mostly likely a bad master swicth. I dont not believe it would be a shorted wire because that would have blown a fuse. Try to power up the window manualy. If they both work properly suspect a bad master switch.:thumb:
Edit: yes your windows will work with the engine off but will operate slower then usaul.
where is the master switch located? I can swap parts from another car.
  • For sale NEW Magnus Forged Transfercase gears
    Parts are new never used. Get some nice parts for a couple bucks off.If I don't replay right...
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
