Borg Warner S200 (Bullseye S256) Review
I believe he has a .70 a/r divded T3 BEP housing.
Well, I thought the divided housings all had higher a/r numbers than .70.
That reminds me, Tom, actually that would be pretty cool if you could put that .85 a/r divided housing on the scale. Since it's lying around not attached to anything at the moment.
Gary
Spendone, here's a good pic of your bay i got at atco. This thing is flying right now :thumb:
Just to keep things updated, I've added an impression of this turbo now several thousand miles later and at 30 psi, including a couple of logs, to the original post.
Several thousand miles later
Just to keep this updated, the turbo is still in great condition with no shaftplay. Performance has still been stellar, as I've recently upped the boost to 29-30 psi. It's now flowing roughly 50 lbs/min (roughly because the 2g MAF is at 3000+Hz and overrun). As far as efficiency goes, I've plotted my numbers on the flow map and I'm still over 70% compressor efficiency, so no problem there. The logs attached for this are "run02012009-4 3rd gear pull.dat" and "run02012009-6 3rd gear pull.dat""
Yeah. Helps with the whole handicapped intercooling situation.
