Boosts to 16-19 psi and then drops and holds steady.
AQua
May 11, 2017
Phoenix, Arizona
Hi guys! So my question is, im boosting at 16-19 psi but once my wastegate opens ( i think ) with that raspy sound my boost drops to 10psi and holds. I know boost drops while rpms increase but is that difference too much? What should i check/look out for? Any advice would help thanks!
Common symptoms of a boost leak. 16-19 psi is also a big margin in terms of boost pressure. What sort of setup are you running (turbo, wastegate etc.)?
Well im running a T28, greddy type s, fp manifold, megan 3 inch exhaust, not sure about the wastegate though. Well time for a blt... some people told me that its the wastegate that needs to be adjusted which i find weird as i thought wastegates are supposed to increase/decrease boost pressure.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
