boosting ?
patsdsm
51
Oct 10, 2004
rochester, Minnesota
i have a 90 eagle talon tsi awd 5spd my car was completely stock i bought a big 16g evo 3 for the car and was running that with no boost controller so the turbo was hitting stock boost around 10-11 psi i just recently put a full 3inch exhaust on my car and am now hittin 17-18psi is his normal or is my wastegate shot or what ive heard that when you put a exhaust on you probley will only gain like 2-3psi but the guy at machv told me that it was tipical to gain that much I'm new to this so all help will be appreciated thanks
Does it slowly rise to 18 as the rpms climb or does it shoot to 18 as soon as boost hits?
Either that is too much boost for the stock fuel system to handle.
your telling me you just put a big turbo and full exhaust on your car without doing any supporting mods :notgood:
sound to me like a case of boost creep and i bet your getting alot of knock to :notgood:
hey thanks for the tip oldman on the porting i will have to get some tools and print off your instructions on porting
Not my instructions, the article was put together by Chadillac2000 and he deserves all the credit for that. :thumb:
I will also answer your pm here. Evo3 o2 housing flows slightly better than a 2G but still has to be ported regardless. Evo 3 outlet is also angled differently so modification to the DP is required if you choose to go with the evo3. Here is another thread that covers not only the turbine housing but intake manifold and O2 housing as well. Happy porting. ;)
Evo3 O2 Flows about 20% more than stock. (just throwin' out some numbers because it's fun!) :thumb:
If you have seen some of the 2G O2 housings I have ported, you wouldn't exactly call it stock. :p
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
