Boost problems... the never ending saga
prodsm
258
Nov 12, 2002
canada,
Hey,
*18 Vac at idle and about 21 when im cruzing*
The problem is my car dosent want to boost past 6PSI above 3500 Rpm,
when I step on the gas my boost increases then comes to a dead
stop when it gets to 6PSI.
Im thinking it could be:
-Waste Gate Acut. lose
-Vacume leak
-Flapper Stuck open
Any other things i should check for or any other input you can give me?
Thanks
:talon: :dsm:
It could easily be your wastegate port degrading. At 155K, mine looked like someone took an acetylene torch to it. The exhaust is a tough environment.
