Boost leak?
gofast63
381
28
Apr 22, 2011
Manchester, Michigan
This is a weird issue I have. i used soap and water to find the leaks I had. My turbo likes to creep to 18psi-20psi, running 450cc, bucks at 5500 then sometimes 6000 at WOT, my wideband will go -- when it bucks. But even if I go 60-75% throttle to keep around to 10-12psi it will buck very little at 5500 rpm. It's always at that point. The head is completely rebuilt so is the engine.
Things I have done:
Boost leak test many time.LOL none I can find.ROFL
Cleaned and gapped plugs to .28 ( their new nkg )
Checked for exhaust leaks. I do have a leak coming out of the flapper from the turbo. Probably explains the creep. (Seafoam)
Adjusted the greedy type s. Also replace the o-ring cause it was leaking. Yes this bov is a peice of sh!t.
Bov is recirculated
Things to do next:
Oil pan gasket leaking pressure???
Fuel pressure. I'll be surprised if it's out of adjustment. I always have it at 43 psi
Leak down test....:cry:
What am I missing?
I had a similar problem on my 2G, ended up being one of the spark plug cables going bad.. It would only do it under a load/boost.. Just thot I'd mention that.. Hope its nothing too serious..
