2G Boost leak test
Not really. Your boost control vacuum line should be pinched off. But you probably have bigger problems if youre holding no boost at all. How do you have it set up?
All I did was make a boost leak tester and the tester has no leaks at all. I hooked it up to my turbo and that's all I did, do I need to do anything else?
It's as simple as that. You very well could have that bad of a boost leak! Where is the air going? It has to be exiting somewhere. I know it sucks but you're going to have to track it down!
Use warm water and soap in a spray bottle. Bubbles will form where the air is escaping. I would bet that your shaft seals are leaking if you are holding little pressure. Also check the injector seals on the intake manifold as well.
Your system isn't holding pressure because your engine isn't in top dead center. the air is leaking through the valves; LOL. Put it in top dead center, and then voila
The shaft seals are on each side of the TB. There is one under the TPS, and the other is on the opposite side where you will find the throttle cable connected.
Top Dead Center, is when your pistons are at the top position, and at its furthest point. When so doing, the valves close.
Good video:
voi·la
vwäˈlä/
exclamation
  1. there it is; there you are.
Can you guys see those metal ring type things in the pictures I just added? They're creating tons of bubbles how do I fix that
That could be the shaft seal, or the TB gasket on that side.
Guys stop it, it isn't working because his car isn't at TDC. It's like pouring water in a cup that has a hole in the bottom.
That would be your shaft seals. Try spraying the other side, it'll probably leak out of the sensor.
http://www.ca.dsm.org/FAQ/tb-shaftseals.html
don't forget to check your brake booster, injector seals, bov adjustment and fpr adjustment. Also listen inside the car if you have an aftermarket boost gauge.
What do you mean listen inside the car if you have a after market boost guage?
