Boost Leak Test Issues
jay1892
64
Apr 1, 2010
Everett, Washington
I tested directly into my T-25, pushing around 20 lbs, removed my pcv valve. Didn't check to see if I was top dead center. Used soapy water.
When I tested it, I didn't remove my oil cap.
I continued to hear air surging through my valve cover.
Is this a seriour issue or is it normal?
Well i would imagine a valve was open when you did the test. Did you hear the air surge through the valve cover gasket? I would assume if you did that you also see oil coming from your valve cover gasket. It wouldnt be a serious issue assuming valves are open.
I would check to see that you have the spark plug gaskets on your valve cover, might be the source of the air.
Is this even a serious response? Please explain to me what in the hell spark plug well gaskets would have to do with air entering the crank case during a boost leak test... Here I think you should read this " http://www.howstuffworks.com/engine.htm " before you make another post it might help you
  • For sale 1g Assortment of New, Used, and Unobtanium Parts
    All good stuff. Will sell individually or lot sale.
    • 8716valver
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale Injen Intake System
    Good condition used Injen Intake System for Turbo DSMs
    • kyler021
  • For sale 1g 1G Driver & Passenger Door Jam Seals
    1G Driver & Passenger Door Jam Seals $50 + shipping & paypal fees* these are the door jam...
