gijoe985
- 562
- 20
- Dec 13, 2007
Grandview,
Washington
So, I have all of the vacuum ports on the throttle body blocked off, but had the hoses still there. I noticed boost pressure coming from a hose. Turns out there was boost pressure leaking out of the egr valve actuator. Now, if I plug that with my finger, it obviously opens the egr because all my boost pressure drops and I can hear it exit the exhaust. So, I assume this means that I must block off my egr? If I leave it unplugged, boost comes out the nipple. If I plug it, the egr opens and boost goes out the exhaust.
Is this normal operation? I assumed that it should be receiving a vacuum signal from that port, not sending boost out of it? Maybe one of you have ran into this before...
