Hiitman
- 482
- 4
- May 12, 2004
Colorado Spring,
Colorado
Finally got a compressor so now Im going over my whole setup checking for boost leaks. I found two. One at the wastegate and one at the throttle body. Ive got a turbosmarts streetgate 38. The leak is coming from where the shaft exits from the top of the wastegate. the other leak is coming from around the throttle body. I havnt figured out if its either the IC pipe-TB gasket, TB-intake manifold gasket, or the o-ring where the throttle cables attaches to the trottle body (couldnt find the name in either manual). i included pics of both.
. ive got a defi boost gauge. the car is on when testing. ive got my boost leak tester bolted up to the intake on my turbo. my boost controller goes from the lower nipple on the wastegate to the turbo.
it was just this little guy. gonna replace and ziptie. but now with my boost controller line that goes to the wastegate plugged and by pinching this line i can get it up to 15 psi
